Here is a picture of my stupid turbo manifold. I guess it was designed for a d16a6 because on the z6 the wastegate hits the upper radiator hose housing:
Here is a picture of the flange I got....I love this thing because it is already cnc'd for 3 inch dp. It looks like I am going to have to port match it to the turbo because it is a little small.:
Here it is with the turbo mounted on the motor stand:
I would watch that manifold very carefully, those welds are severly undercut(not enough filler rod). Also the turbo being clocked at that angle **could** cause problems
Yeah the welds on the manifold are not the greatest. It is a very old revhard race mani. I really wish I could take and re-weld it, but alot of the reason for going back to d is the extra money I got from my b16a I bought a lincoln 3200 hd, a tank, a chop saw, a bench grinder and a bit of other extra stuff. I want to make a ramhorn style one soon.
As far as the way the turbo is sitting, I would like to know more of what your talking about.
It won't fit, the turbo hits the block. I mean it is not even close. This is how my last setup was, with the DP on the a/c side. this way is better cause of the dp. I really wished it was that way I accidently put the turbo on like you said today, and that one bolt by the oil inlet is a MFPITA!!!
If you picture the shaft of the turbo, it should go parallel to the ground or atleast very close. With the pictures shown, the shaft seems to be at an angle. Theoretically this can cause bearing issues and things of that nature. I just figured i would mention, but honestly dont think there is a whole lot to worry in this case. The undercut welds are more of my concern but if you are aware they could be problematic then thats the end of that.
Oh o.k. I see what your getting at. It must be the camera angle, cause it sits pretty "square" to the ground Here is a clearance pict, image the exhaust housing sitting theother way. There is no way to clock the housing and it bolts on to the mani. Of course everything can be clocked from that point, but it wouldn't help.
I hope you did NOT lay any parts on that dirty floor then install them on your motor. that's once NASTY buildup area if your usig that to rebuild that honda motor.
Nah it is perfectly clean dude. Seriously that was scrubed with industrial simple green not more than two days before. It is just really wierd concrete. It's like it stains really easy. Plus I'm a clean freak I sweep up at least once an hour. I don't like stepping on stuff.
Don't jump to conclusions when you really do not know.
Anybody got a photo of the JRSC Y8 (3 RIB) Crank pulley or a photo of it next to a stocker?
Was there ever a 4 rib crank pulley produced by Jackson Racing?
Hey guys!
Im going to turbocharge my d16y7 soon and I was wondering about engine management, If i say id buy an P28 socketed and chipped ecu from H-tune. co . uk, Can i plug that ecu to my computer and connect it with Crome or whichever tuning software we use?
Thanks!:online2long:
Hey guys i just bought a civic with a built d16 turbo engine with the common vitara setup, its been running fine but the manifold was cracked badly and blowed like hell also looked like a 10year old welded the manifold so the quality is s*it. im not a bad welder and considering making a new...
Hi guys!!!
Some of you probably seen my car before!!!
So now its time to post my full built thread!!!
After a long time,lots of money,stress and working ours i made the faster and most powerfull D16 for greek standards!!!LoL
Down here they never tried to turbo a d16,so since i came back from...
Been working on a turbo setup for my crx for a few years, just put motor in, finally ready for the turbo.
I was wondering on the effects of altitude on a turbo setup.
I spend 1/2 my time in Denver, about 5000', and the other 1/2 up in Frisco, my driveway is at 9200'. Some of the mountain...
