1 - 11 of 11 Posts
My y8 turbo tuned s300 on e85 is all the sudden bogging hard at 3k and i cant barely accelerate. It seems to only be under load at a stop in nuetral i can rev fully. The cel isnt coming on. Im not sure where to start any ideas?
Its been running perfect for months. I do still have the stock headbolts on it could this be head lift? i dont see any oil in the coolant.
is it under WOT or just under any load?
Its under any load. Its a fresh tank and i havent heard of that.
Do you have a wideband?
Have you checked your spark plugs?
Did you change your fuel filter after you switched to E85? (E85 can and does loosen crap up in the fuel system, which can lead to plugging the filter way faster than normal, preventing it from flowing enough fuel to keep up with the demand of engines under load.)
I had to replace my fuel filter at about 500 miles after switching to e85 because it cleaned all the crap out of my system...haven't had it clog since. I would check your plugs and your fuel filter.
I dont have a wideband. Il try a new fuel filter and plugs tommorow. Thanks for the help guys.
Thanks for the input i didnt know that about e85 i havent changed it since i switched just the injectors and fuel pump.
What am i looking for on the plugs?
well you should change your plugs eveytime you change your oil really. with your motor being turboed it has to burn a lot more fuel than a factory tuned car would.
Fuel filter ftw! swapped this morning and its running great so far! Im going to do the plugs next oil change also. Thanks for the help guys.
1 - 11 of 11 Posts
