1 - 11 of 11 Posts
turn it around, and reclock it. run a narrow radiator. have a downpipe yet?
btw, is that an ebay manifold and ebay turbo?
Acura TL-P
Correct, the turbo isn't too big, you just have to turn it around. By the looks of it you'll need a new downpipe (from the pic it looks like it is setup to install the way you have it) Also, unblock the wastegate port, and start saving for a new mani.
We can also make a DP for you if you need one.
yeah i already have a downpipe and yes it is an ebay turbo and manifold. so if I can't mount it driverside dp then can I just rotate the turbo? for some reason it looks as though the oil inlet is on bottom and the exit is on top. now I know that will not work so how can I rotate the center and cold side?
racist-bigot-sexist-homophob
Unbolt, rotate.
you maight also wanna look into an eg half radiator if you need more room
1 - 11 of 11 Posts
