1 - 18 of 18 Posts
i was just wondering what is the best/cheapest throttle body to use for a turbo build...or do u guys know what the max size of a d15b throttle body..thanks guys
FAMILY MEMBER #316
max bore can bore your TB out for 100 beans....prolly your best bet...gotta pay to play. turboing a car...even HMT way will get expensive
R2.....Zap Balls
do u know what the max size would be.....if its like 68 or so i would be fine with 100$ .....better then buying a skunk 2 that is 68/70 for over 250$ u know
That's a huge throttle body...
I honestly don't know what would be ideal for boost, but I would think 62 or 64 should be fine.
man you'll be good to go with a 60mm tb. any more will fuck up your air velocity
Just pick up a B series tb for 50 bucks, port match it to your intake manifold and be done with it.
That's definitely true in a N/A application. In fact, for most setups, 60mm would be too big as it is.
Although, like I said, I really don't know what the best size would be if you're boosting to the 300+ whp range...
R2.....Zap Balls
you'll be fine with oem. Bizzar is making 300+ with the stock im, tb, and head.
insert user title here
my tb and im were both stock and this was on a 405 hp setup.
on pump gas i was probably in the 350 range. of course this was a z6 tb but that shows that oem works just fine.
Well, I think this thread is now closed :p
1 - 18 of 18 Posts
