1 - 20 of 29 Posts
Im currently running eagle rods, srp pistons, head studs, bisi level 3.6 cam. I need a new turbo but i want something that will support a 80mm sleeved fully port and polished built z6 in the future. I was looking at SC6262 turbos but im not 100% sure it will work for the 400whp i want to make now.
Any suggestions or am i going to need two different turbos?
Trying to stay in the $900 range as well. needs to be t3 and 5 bolt discharge
Wow nice set up.
Should i go with the E cover or the S cover is the next question or wont it matter?
Might consider a Holset HX40/HX35 hybrid. I know the DSM guys have had good luck with the setup in the 350 to 550hp range and great spool.
i dont have them yet just looking into them for now. Have a lot to talk about with mr. bisimoto
My biggest issue right now is that im trying to make 400whp on a 75mm built z6. Which has everything but a port and polish and sleeves. Will i be able to do this with a decent powerband with the 6262 with a .63 ar t3 hot side? Or is it going to lag beyond use. Also keep in mind this is my somewhat daily.
1 - 20 of 29 Posts
