1 - 20 of 61 Posts
EJ6
Fill in the blanks, so we can get an idea what different turbos spool like on different set-ups. :)
Engine -
Turbo -
Manifold Type -
Exhaust Diameter -
1 psi @ RPM -
Max Psi @ RPM -
# HP, # TQ -
1/4 mile time -
racist-bigot-sexist-homophob
There's already a thread like this.
Engine
Turbo - ebay t3/t4 57 trim
Manifold Type - mini ram
Exhaust Diameter - 3" turbo back, no cat
Begin Spool @ RPM - 2600rpm
Max Psi @ RPM - 10 psi at 3800 rpm
# HP, # TQ - ? never been dynoed
1/4 mile time - never run the quarter
Fill in the blanks!!! :)
he means fill it in like i did above....
ok, i'll play your little game..
Engine = one that runs
Turbo the kind that spools
Manifold Type the metal type
Exhaust Diameter large
Begin Spool @ RPM not soon enough
Max Psi @ RPM depends on elevation
# HP, # TQ random numbers that dont mean squat
1/4 mile time i got kicked off the track cause i deal crack
good enough? :bigok:
1998 Civic coupe ex
Engine = d16y8
Manifold = made of old ssautocrap flanges and thick wall tubing
Exhaust Diameter = 2.5in
Begin Spool @ RPM 2900
Max Psi @ RPM 8psi @ 4500
# HP unknown, # TQ No idea
1/4 mile time no idea yet
1/8 mile time [email protected]
EJ6
mrfunktastic, it seems like your set-up works pretty well, that is a nice RPM to begin spool and it's also good to have 10psi on a t3/t4 57 trim by 3800rpm on a d-series.
anyone else?
Lifetime Awesome Member
'89 CRX HF
Engine = gee is that whats under the hood
Manifold yes
Exhaust Diameter my arm
Max Psi @ RPM various
# HP, # TQ no hot parts and no tickets
1/4 mile time 7.5sec on highway at 120
for god sakes i dont post much but then again i know how to read
ya, not really funny at all. maybe try contributing next time...
spool varies with the tune to, add fuel and retard timing to promote earlier boost building
i lowered my full boost point by 750rpm simply by tuning a bit
Engine - 235,000 stock z6
Turbo -t3/t4 .50ar col .63ar hot used off ebay
Manifold Type - cast ebay, ported polished and heat wrapped
Exhaust Diameter -2.5" all the way back
Begin Spool @ RPM -3750ish depending on the gear and if the clutch feels like holding
Max Psi @ RPM -11psi all the way up to fuel cut
# HP, # TQ -
1/4 mile time -
EJ6
back on topic
Engine -d16y7/y8 w/ cp 9:1
Turbo - Greddy 15g
Manifold Type - Greddy cast
Exhaust Diameter - 2.36 apexi ws2
Begin Spool @ RPM - 2700 rpm
Max Psi @ RPM - 13 psi at 5000
# HP, # TQ - 242hp/215tq
1/4 mile time - N/A
the short bus
Engine - Vitara Y7 bottom with Y8 10300 cam
Turbo - Ebay 57/63 "50" trim
Manifold Type - i/m= Edelbrock victor X E/m= ebay cast
Exhaust Diameter - 3" turbo back no cat
Begin Spool @ RPM - 3200
Max Psi @ RPM - 17psi @ around 5000
# HP, # TQ - 272Whp 245wtq
1/4 mile time - good question lol
'89 CRX HF
Engine -9.2:1 forged a6
Turbo - t3/t4 .48/.60 60 trim
Manifold Type - homemade mini-ram
Exhaust Diameter - 3" DP, 3" crush bent
Begin Spool @ RPM - 3k
Max Psi @ RPM - 21psi @ 4200(high load, high gear)
# HP, # TQ - 221/187 @ 10.5psi(didnt run 21psi on dyno)
1/4 mile time -12.87 @ 109mph
EJ6
Discussion Starter #18
I know there is lots more people on here with useful input
1997 Honda CRV
Stock D16y7 with ARP head studs - 124,xxx miles
Master Power Turbo .42/.48
Mini ram horn and stock z6 IM
2.5" downpipe with high flow cat to 2 1/4" magnaflow exhaust
Tiny turbo, mini ram horn = really quick spool. 2000rpm starts spooling around, full boost by 4000rpm maybe sooner.
14psi around 4000rpm
178whp and 16X trq on a dyno that is quoted to be 50whp off. Dyno is only a tool for tuning not an exact figure.
13.343 @ 101mph with a 1.802 60 foot. = Made possible by MH 24.5 inch slicks on lensos, also a beefy traction bar and stage 4 clutch.
YouTube - D16y7 Turbo 09 NEDW Import Wars
Engine - stock d16z6
Turbo - t3/t4 57trim
Manifold Type - miniram
Exhaust Diameter - 3" straight through
Begin Spool @ RPM - 2500ish
Max Psi @ RPM - 11psi @ 4000ish
# HP, # TQ - 282hp, 243 lbft
1/4 mile time - 13.1 @ 109mph
1 - 20 of 61 Posts
