1 - 20 of 33 Posts
Im currently building a D16z6 with a fully built head(port job,Valve's etc)
will have vitara's eventually which i think would put my compression around 8.5:1 so my question 2 u guys is what tubo would you use to get 350whp with as quick spool time as possible on 91octane pump gas??
make that much power your going to need a big turbo. 50 trim might get the job done but the bigger the turbo the horsepower your going to make. id go with a 57trim turbo and should make that power easy.
1.8 nawz powa
Well im sure you know the t3/t4s are a poor mans turbo. If you looking for that kinda power+quick spool, your gonna have to go BB. When you say quick spool how soon would you like it?
i want full boost around 3000-3500 rpm. and it has to be a T3/T4 cause i already have a stainless tubular manifold with a t3 flange. also will getting a lighter flywheel increase spool time?
1.8 nawz powa
Yes a flywheel can help. So people just cant get traction with one too light. If you have to run a T3....and want it to spool at that low...Im not sure your gonna be able to get the power your aimin for.
The Master Fabricator
buy the smallest turbo you can, that is capable of 350whp.
X2 - TOTALLY AGREE!!!
Full boost at 3000-3500 rpm and 350hp... come on be realistic... maybe in 5th from a 20mph roll LOL. The Boost pressure you build is dependent on load/gear
You need to do some more research...
well what i really want is for power to come on as early as possible cause i do alot of city driving(light to light) so id be willing to sacrifce some power and get a smaller turbo to get earlier spool times
1.8 nawz powa
If you want quick spool times for light to light just get a T3. A little more power you can get a T3/T4 but it will only need to be like a .48 if that.
1.8 nawz powa
No problem man, what were here for. I had a buddy who had a bone stock y8 with a T3 and he put down 210whp so maybe if the turbo do max out you can get close to 300.
Random Hero
yes it will.
you wont want a light flywheel for light to light driving.
another point to consider: withan ex/si tranny you can rev the engine pretty quicky in first and second gear.
I like the idea of turning down your power goals for better power usability. really you want the flattest torque curve you can get, not 350whp.
people might not be impressed when you say 270 whp daily driver, but when you give them a ride, they might shit themselves.
^Great torque there! T-bird turbo is probably going to be my first turbo... Just gotta decide on the auto turbo (.48/.63) or the manual turbo (.60/.63). Guessing for the quicker spool, go with the .48...
1 - 20 of 33 Posts
