S
I was planning on putting a turbo on my d15b7 block/ Z6 vtec head. I wanted to put a turbo on this summer or atleast try to. Im trying to get as much info on this as i can because Im not really familiar w/ turbo. I wanted to lower the compression to 9.5:1 and probably run 6 psi which I heard would be safe. I was wondering if i had a compression of 10.5:1 what would be a safe psi to push ? Finally I wanted to know what turbo would be good for this set up ?
S
I've seen turbo kits for 92-95 dx motors for the 1.5l, I really dont get why that might happen to my car if I go turbo. Any other opinions ?
H
You should be safe boosting your mini me - I'd say at least 5-7 psi. Make sure you have enough fuel....
S
yeah I just plan on going low boost for the time being. I just need info about it. I was wondering also if anyone else has done this to this setup before...
