1 - 7 of 7 Posts
my turbo will NOT create boost. Wastegate is NOT stuck open. made 1lbs of boost on the dyno. WHAT IS THE ISSUE? i checked the piping etc. what else could it be?
if the leak is so bad only 1psi was measured, you should be able to actually hear the leak.
1 - 7 of 7 Posts
