1 - 7 of 7 Posts
I
I saw that there was a turbo kit for the D-16Y8. But i was thinking can the manifold from that kit fit on my D-16A6? Or should i got with another company for the manifold? I want to run a T25 from an eclipse.
B
Yea the mani would work on your engine, but not with that turbo.
B
I'm pretty sure but not positive so you might want to check elsewhere.
4
That kit will bolt right up to your a6. remember, a D is a D as far as sohc bolt patterns go. if it *were a zc it would not. its s a "D" dohc non-vtec.
post up a pic of the turbo flange, and ill tell you if its a t-25
O
any "T" trpy tuebos will not bolt to the greddy doe tot he greddy only supporting mitsubishi type turbos. thos are a unusual bolt patters and are much smaller than the t flanges. some are even 3 bolt pattern.
1 - 7 of 7 Posts
