1 - 7 of 7 Posts
I bought this kit from xs power b/c i was on a budget and i was woundering if it was alrite
MANIFOLD - BRAND NEW - STAINLESS
TURBO T3/T4 T04E SUPER 5 BOLT .50 .63 WITH 2 YR WARRANTY
INTERCOOLER 24 X 12 X 76MM
WASTEGATE 38MM
SUPER 3" BRAIDED DOWNPIPE
BLOW OFF VALVE
DOWNPIPE EXTENSION
FLANGES
GASKETS
FLANGE FOR BOV
FLANGE KIT FOR WASTEGATE
MANIFOLD DETAILS
This manifold was custom-made to be used with a 35mm external wastegate
and this manifold and down-pipe allows you to retain A/C and power steering.
This manifold and downpipe is for T3 and T3/T4 Turbos.
The manifold and down-pipe are both made out of SUS304 Hi-Grade Stainless to help disperse heat.
This manifold is drag-race quality, and similarly design manifolds can be found on professional drag cars.
Manifold has flange for an external wastegate. And since this manifold is tubular steel,
it flows better than cheap cast iron and is less prone to cracking.
Down-pipe allows you to retain your A/C and power steering.
There is a flange for the end of the down-pipe will bolt-on to your
catalytic converter so you do no have to cut and weld your exhaust to make this down-pipe fit.
Down-pipe also has a bung for the O2 sensor.
T3/T4 TURBO DETAILS
3" INLET DIAMETER
2" OUTLET
WET FLOATING BEARINGS
1/8 NPT OIL INLET
T3 / T4 FOOTPRINT OK !!
SPECS:
.50 A/R / .63 HOT SIDE
STAGE III WHEEL
BALANCED AND BLUEPRINTED AND COMPRESSION TESTED
LOL. I just thought that was funny. But good luck with it.
98 civic
the mani. will crack and the DP will suck ass. im running a XSpower WG. that guy with the name of autoworks is who you should have talked to looking at kits he is a good man :tu:. good lick with the kit. i would say find yourself a cast log mani and a DP cough cough autoworks
1 - 7 of 7 Posts
