1 - 9 of 9 Posts
Have a problem with my y7 it seems like the idle is backwards. Cold start itll idle low around 800-1000 when its warm it idles high at 1500rpm. How do i drop the idle down lower? I have cleaned the iacv
Its a d16y7 on a 97 ek coupe. It is vitara/eagle rods. Arp headstuds cometic multilayer gasket. Supertech valve springs. Aem cam gear. It is a obd1 p28 s300. I messed with the idle screw after i posted and it dropped the idle down to about 900-1000( warmed up engine to normal temp) but then i had to hold the gas a little when starting and also when i am driving and switch gears or push the clutch or go in neutral it drops down so low it almost stalls.
1 - 9 of 9 Posts
