1 - 4 of 4 Posts
EMAIL IS THE BEST CONTACT METHOD: [email protected]
My last thread got a bit messy and I'm still getting a lot of emails regarding sold parts. Here is the revised version, only the parts LISTED are for sale.
I have stack of used parts and a few BNIB parts
**Please respect my time and not bother me with photo requests for a brand new OEM rear main seal, etc**
**ALL PRICES ARE OBO**
- Shipping and Paypal fees will be negotiated upon sale.
- Discounts for multiple items.
USED PARTS:
**ALL PARTS HAVE APPROX 2000 MILES UNLESS OTHERWISE NOTED, THIS CAR WAS BUILT IN ONE SHOT!!**
Engine:
- D16Z6 Head Complete w/
- Bisimoto 2.4 Turbo Cam, Springs, and Retainers. Supertech Valves, and AEM Cam Gear: $800
- **I had intentions on rebuilding this car, as such this head was resurfaced, hence why it's packaged shiny and new**
- Bottom End:
- D16Z6 75.5 CP Pistons with Scat H Beam Rods and ARP 2000 Bolts: $650
- I Believe these can be used with other D - Series Engines, do your homework.
- One Piston was replaced with a brand new in box unit that's included in the sale. I damaged one during disassembly, long story.
- Piston tops have light scratches from using a screw driver to find TDC - they were run like this, and I'm positive this has no effect on performance.
- I cleaned up one piston just to show their overall condition.
- Throwing in OEM Thrust Bearings.
- OEM D16Z6 Crank: $100
- OEM D16Z6 Oil Pump: $75
- OEM D16Z6 Tensionor: $40
- OEM D16Z6 Water Pump: $40
- Gates Racing Timing Belt: $40
- OEM D16Z6 Dizzy: $50
- OEM Starter: $50
- OEM Alternator: $50
Transmission:
- D16 S20 Transmission with FULL Synchrotech Carbon Master Rebuild Kit: $300
- Brass Synchros with Carbon Lining with all OEM Bearings and Seals SHIFTS PERFECT
- Competition Stage 4 Clutch: $250
- Competition Ultra Lightweight Flywheel 8.8 Lbs: $150
Cooling:
- Mishimoto Radiator with Shroud and Fan: also includes NSX Rad Cap: $250
Suspension/Chassis:
- Hasport Engine Mounts P/N: DCSTK Race 70A: $250
- These just need a nice metal polish to look new again.
- Skunk2 Rear LCA's: $100 - New bushings needed.
- Suspension Techniques 25mm Front and 19mm Rear Sway Bars: $300 (prefer selling as a pair)
- Chassis Mounted Front Splitter: $200
- I do not currently have my own pictures of this, here is a link to the original creator/owner's thread, this is the exact item in my possession, please copy and paste link:
my diy front splitter - Honda-Tech
MISC:
- OEM Honda Mud Guards for 1993 Civic Coupe, I don't know how I ended up with 5, but you get all 5: $50
BRAND NEW IN BOX PARTS:
Engine:
- OEM D16Z6 Head Gasket (BNIB): $50
- Misc OEM D16Z6 Gaskets and Seals, Valve Cover, Rear Main, Oil, etc. The part numbers are shown below, I'd rather not separate this stuff $50 takes the whole lot.
Brakes:
- Power Stop K699 Brake Kit: Front Cross/Slotted Rotors and Pads (BNIB): $75
- Dorman Brake Master Cylinder: $20
Bushings/Wheel Studs/Bearings:
- Energy Suspension Bushings:
- Front Control Arm 16.3105R Kit: $30
- Front Shock Kit 16.8102R Kit: $15
- Rack and Pinion 16.10102R Kit: $10
- Moog Lower Ball Joints Pair: $50
1 - 4 of 4 Posts
