i am setting up my first car for a turbo. at the moment i have the stock d15b7
with a d16a6 cam i am going to put on a diy ported head that i did myself and arp headstuds. i am hoping for around 160-180hp on 6-8 psi
i bough a used airesearch m27 turbo for 140 online. i looked it up and as far as i can tell it is the same bearing housing as a garrett t3 it is a journal bearing turbo and water cooled.
turbo specs are:
compresser
inducer 40.50 mm
exducer 60.24
trim is 45
.42 a/r
turbine
inducer 48.76mm
exducer 58.3
70 trim
.63 a/r
all numbers were what i measured off of it
im going to make my own header. are there any good designs that are that much better? i was thinking of doing a 4 into 2 into a collector and try to make them as equal length as possible.
for tuning i am going to buy a chipping kit from xencron along with a chip burner and a lc1 wideband o2 sensor
tomorow i am going to get a hks blow off valve for 100 through craigslist.
and i have a chunk of 3" diameter solid aluminum that i am planning on machining into a oil sandwich adapter.
what do you guys think?
turbo specs are:
compresser
inducer 40.50 mm
exducer 60.24
trim is 45
.42 a/r
turbine
inducer 48.76mm
exducer 58.3
70 trim
.63 a/r
