1 - 3 of 3 Posts
I need some to make a checklist as to what I need to run a basic turbo setup, the bare minimum. I am using upgraded pistons and rods but I am only using two fuel pressure regulators instead of a fancy fuel management. If someone could write down everything that is needed (oil lines, gaskets, etc.) for me to make it work that would appreciated on my part.
1998 civic hatch
D16a6 block
D16z6 head
hopefully boostin around 7psi
the hard-parker
check out the "turbo noobs" FAQ and that should answer all your questions. let us know if you have any more questions :)
ok here you go
Bare minumum!!!!!
Turbo charger
manifold
oil feed and return lines
charge piping
downpipe
this will for sure make your car blow up unless you only run 3 p.s.i
Now if you like your motor or turbocharger have this.
Blow off valve
any kind of fuel management, even FMU
intercooler
1 - 3 of 3 Posts
