I'm going Turbo on my Civic. I have most of the parts and need advice as I am new to turbo Civics.
I have a 98 DX Coupe with a D16y7.
I currently have I/H/E and a Y8 Manifold and TB.
I know I will lose the I and the H when I install the Turbo.
These are the parts I have, I plan to start with 7 psi max.
T3/T4 T04 57 Compressor wheel trim, .63 A/R turbine, .50 A/R Compressor
T3/T4 Manifold with External 38mm Wastegate
Type S BOV
3 Inch Stainless Downpipe with High flow Cat(May not use the cat)
Front Mount Intercooler with all piping.
Manual Boost Controller
Turbo Oil Lines feed and return
All hoses, T's and fittings.
This is everything I have. What am I missing?
Can I run this at 7 Psi safely?
Am I going to need an FMU or Injectors? What size injectors and what ratio FMU?
I know everyone says FMU's are no good but every quality kit I see runs one.
I am only running 7 PSI after all.
Will I need a new fuel fump and FPR?
I am running a Y8 Manifold, Rail, Injectors, FPR and Throttle body. All of which are in new condition.
What kind of times should I expect from a Y7 Turboed with a T3/T4 at 7PSI?
My car has no A/C and is light.
Thanks for your input.
Dan
Type S BOV
Dan
