1 - 20 of 25 Posts
I have a d16z6 obd1. I finished the whole build including 460cc rx7 injectors. I chipped my ecu and downloaded a basemap. When I turned the key for the first time my engine ran for about 10 seconds before choking and flooding
I pulled the spark plugs to make sure they are working, no start
I pulled the J1 jumper on my ecu to get my stock basemap back, no start
It seems like my chip isn't working because way too much fuel is being put in as if my ecu still thinks it's running 240cc injectors. Any suggestions please?!? I need help!
I tried the stock p28 basemap but with bigger injectors but nothing happened...unless it's just too flooded to start no matter what
Well.......
Have you ever tuned a car before?
Also you might have the chip turned around backwards... idk
Maybe someone with more knowledge will come along and help you.
Aslo you might to let us know which program your running and the emulators and what not your using
I'm using crome....a burns2 chip burner. And I've double checked my chip and socket placement. I hope I don't have a bad 28 pin socket for the chip. Yeah I'd really love to have an expert on this help me out
EDIT: answered already ha
I had a similar situation with my previous turbo ek and it turned out to just be a bad chip from Phearable. Did you try just re burning a new chip?
Krueger, I only have the one chip ATM. But it's been burning fine. Does that mean the chip is good or do I have to buy another one?
Not quite yet, i wouldnt just assume thats it, just thought maybe if you had an extra to try it. But maybe do some more research before jumping to it. Just was an idea since i had a similar issue.
Borrow A stock p28 from someone if you can. it should run on a stock p28 just idle really crappy if its the chip thats the problem
remove j1 jumper and put stock injectors back in.
Try to start and run her like that.
IF she starts and runs then move on to burning a stock map onto a chip.
She if she starts like that if no then something is wrong with the chip, burner, or ecu.
Somehow it's not recognizing my chip :( it's really depressing. So it still thinks I have 240cc injectors so it's just wizzing fuel everywhere and running super rich. Anyone know how I can make is see the chip?
Retired From Hondas
Your Doing It Wrong!
I'm using crome....a burns2 chip burner. And I've double checked my chip and socket placement. I hope I don't have a bad 28 pin socket for the chip Yeah I'd really love to have an expert on this help me out.
Your in the right place and this would be Quote #2
How do you know? See quote #2
This ^
See Quote #2
If you still have the stock injectors put them back in and see if it will idle
And This ^^
Discussion Starter #16
Hey does anyone know what happens if the J1 is in but the chip isn't? Does it run the stock chip or just not start?
Retired From Hondas
im guessing the OP knows that you cant just plug in any injector and expect them to work properly.
1 - 20 of 25 Posts
