from what I've read so far, they use tungsten because it is extremely dense, hence small pieces of the metal can be used allowing for greater precision.
a full tungsten crank would be extremely heavy. I don't think that will mean more torque. it is the same as a light / heavy flywheel in that the crank will not *create* any torque; merely store momentum when it is being accelerated, do nothing at steady speed and release said momentum when it is being decelerated. it is going to be a bitch to accelerate.
a fixed amount of torque will impart a fixed momentum. momentum = mass * velocity.
if you increase mass and keep momentum constant, velocity has to decrease. so for ever unit of fuel burnt, a hypothetical tungsten crank will rotate slower than a steel crank.
