1 - 20 of 30 Posts
are the eagle h-beams better than the tunertoys? because i can get the eagles for 280 + S&H and the TT for 220 + S&H
basically are the eagles worth the extra 60 bucks
4 doors of fury!!!!
ive heard nithing but good things about tt rods. i plan on purchasing a set soon for my vitara build.
+ they are an affiliate.
I'd probably just go with the tt rods cause there cheaper. more money for other shit.
Curious if you can feel the difference between the .6-8 compressin between the vitaras and stock pistons??
Tuner Toys are made by Golden Eagle..... You really need to do your homework before you type....
So what about these SRM H beam rods http://cgi.ebay.com/ebaymotors/SRM-H-Beam-Rods-Honda-D16-SOHC-ALL-VTEC-ZC-Turbo-SALE_W0QQcmdZViewItemQQcategoryZ33623QQihZ010QQitemZ200162338347QQrdZ1QQsspagenameZWDVW
Premium Forged 4340 steel
Reduced weight
Matched sets ±1 Gram
3D design 2PC forged
X-rayed
Sonic tested
Magnafluxed
Heat treated
Stress relived
Surfaces machined
Stroker clearanced
Rated to 650HP
ARP 3/8" cap bolts
Capable of handling high TURBO BOOST!
Fits Aftermarket Float Type Pistons (JE, CP, Wiseco, and etc.)
C-C Length Notes Gram Weight
5.394" stock length Torque @ 37 lbs/ft oil base 500
So lets hear the bashing on these, cause they are in my setup as we speak.
Lifetime Awesome Member
'89 CRX HF
Reduced weight
X-rayed
Sonic tested
Magnafluxed
Heat treated
Stress relived
Surfaces machined
Stroker clearanced
Rated to 650HP
ARP 3/8" cap bolts
like i posted on td16, just hope that they arent sending you the rods that are in their listing pictures, because they are going to be too short. the description says 5.394", but that 5290 stamped on the side of the rod says otherwise...
yeah I have 5.394 Already made sure of that. he said thats just a picture. Yes I had to notch my block to.
1 - 20 of 30 Posts
