1 - 20 of 31 Posts
1998 Civic Dx Coupe
D16Y7
T3/T4 T04 57 Compressor wheel trim, .63 A/R turbine, .50 A/R Compressor
38mm External Turbosmart Wastegate set @ 7PSI
SSBV Greddy Type Blow Off Valve
Front Mount Intercooler 28"x 5"x 3"x 2.5" Inlet and Outlet
2.5" Intercooler Piping
Walbro 255 LPH ig Flow Fuel Pump
Manual Boost Controller
D16Y8 Intake Manifold
D16Y8 Fuel Injectors, Fuel Rail and Fuel Pressure Regulator
Cast Drag Turbo Manifold
3" Stainless Downpipe
Aluminum Radiator w/ Silicon Hoses
2.5" Exhaust with no Cat
No A/c
No Power Steering
Turbo oil lines and Oil Restrictor
Energy Suspension Transmission Stabilizer bushings
Lots more to come.
Trying to figure out Engine Management and that is all I need.
If I do go with an FMU, wat ratio should I use?
I not sure how to go Crome.
Do I just get the OBD2-OBC1 Harness and an OBD1 Ecu?
How do I get this tuned?
What oil and spark plugs should I get?
My estimate is a [email protected] anyone think otherwise?
Thanks,
Dan
· Resident Gunsmith & Duracoater
Ranger - work truck
well if you are a shitty driver with a riced out junk bucket....15.3
why not go to the track and say look i ran [email protected]xx mph
how can i make it quicker.
ngk plugs, dont even think about an fmu.... and get a chipped ecu
your welcome.
Discussion Starter · #4 ·
I'm a good driver. Alot of my friends have me drive their cars at the track for them. My boy used to run consistent 15.2's and after my first run in his car I got a [email protected] 90 in a 2000 Si.
Should I keep the plugs stock?
Who can tune my Crome when I get it and how much should I pay?
I appreciate your info. 13.4 is good. . . Faster than my V8 Formula.
I'm selling the Formula and going Forged.
Ultimate goal is [email protected]+
· yellow bar for me
viper blue 92 eg
i dont see you running 13.5s on stock injectors. but thats just me. with an FMU it will blow before it ever sees 11s. pgmfi.org is where you go to learn about crome.
Discussion Starter · #8 ·
I'm ordering a forged bottom end tonight. How much should I pay to have it installed? Just labor as I'll be supplying the parts.
After it's forged I'm gonna get a Cam and Head and turn up the Boost to 18-22 PSI.
With a forged bottom.. just get some beefy injectors (440's are probably good till about up to 330whp, but since you got a forged bottom end you're probably expecting more) and then get tuned on CROME.
You can get an ODBII->OBDI conversion harness from http://www.rywire.com/ and then you can use an OBDI ECU and get tuned on CROME. You can either tune it yourself or find someone who tunes CROME in your area (which is what I'm doing).
· yellow bar for me
viper blue 92 eg
im not sure if turbo is such a good idea till you do some more research to learn the world a little more. i would hate to see you blow a shit load of money without knowing what you are doing. why not just assemble and install the forged bottom end your self.
where are you located?
hey watch selling to the noobs. might get the bannination
You're not allowed to sell stuff on this site?
Or is that just to people with under ~65 posts?
.. and by the way, guy who made the original thread, I wouldn't expect breaking into the 13s if you're not going over 7psi. Well, just maybe if you look into getting a bomb ass suspension setup.. Traction bars, slicks.. and an OBX ;)
Discussion Starter · #17 ·
I just installed the Y8 Manifold. Everything was easy. The injector wires and Charcoal canister thing weren't long ago. I started cutting open the loom but I had to go to an appointment.
How much loom do I have to cut off?
Also I left the bracket from the Y7 manifold on for some unknown reason, I think it is oldng up some wires. ow many bolts hold this on? I took off the one bolt tat fastened it to te manifold, question is, Is this removable with te manifold in the car?
I probably wont make it back out till tommorow, can't wait to see if I feel/hear a difference.
Thank for any help,
Dan
1 - 20 of 31 Posts
