1 - 9 of 9 Posts
Bottom end,Eagle rods,YCP vitaras cometic head gasket
Head:supertech valves/springs kit
Neukin manifold, new gasket, tial wastegate/wastegate pipe..cant remember what else...any input would be appreciated
picks of said manifold would be a plus, if its cast then most of the larger turbos will require heavy grinding on the block to remove material to install big turbos
i am currently building engine with a gt2560r smallest of the bigger turbo's and still requires alot of material to be removed.
Every time I see a 92+ turbo setup it always surprises me how much more damn room there is than an EF under the hood.
1992 Civic Si
How much power you wanna make?
Borg Warner S252SXE or S257SXE would be my current choice for a big power D16.
94 Integra
That looks like a t04b cover, so it could be a an S, H, or V-trim (3-400whp). You *need* to measure the small diameter of both wheels w/in 1/16" to get an idea what it really is. To give you an idea why, 1/4" is what separates a 60 trim t3 (300whp) from a 50 trim t4 (425whp). Also count the number of blades - t04b has 8 large & 16 total, t04e has 6/12 count.
If it's an s-trim, 250whp with moderate boost. If it's actually the china 46-trim t04e wheel, 350whp could be done with 15-20psi & a few drops of jesus piss (luck) in your tank.
Ugh that low compression is gonna suck.
yeah I can agree with you there... if I could go back and change my build when I was collecting parts I would've went with a higher compression piston... but they work for what they are.... holding 300whp+ for me for 3 years no problems.... but I would recommend contacting Greg at Go-autoworks for turbo advice and competitive pricing on them... Good luck!
1 - 9 of 9 Posts
