1 - 10 of 10 Posts
So my car won't start.....
It will start if I push it off or use engine starter. Runs GREAT when it starts. It's getting fire, I have checked that.
(BYW, It made 290whp on the dyno today!)lol
Thoughts?
-Michael?
DEAD
crank weak no start
Crank no start
no crank at all
all would proceed differently.
If starting fluid starts the car you have a fuel issue. Start testing the fuel system.
88 Civic Hatch
sounds like it gets vapor locked when its hot.. thats about as far as I can go with it.
thanks for the input. here is an update on whats up...
I have replaced the FPR and that was not the issue..
I have node tested the injectors, thats not the issue...
I replaced the dizzy, NOPE.... not the issue.....
It starts when its cold or just slightly heated up but once it reached FULL operating temp it will NOT start without starter fluid/spray.
I'm honestly at a loss, My tuner (scotty at Mainstream Performance in Atl) is puzzled. So now we are just shooting in the dark on what the issue is.
ah darn my tuner can't figure it out.
adjusting fuel and ignition maps, cam timing, etc. to make the most power is different then diagnostics.
1 - 10 of 10 Posts
