1 - 7 of 7 Posts
C
ok... my car (1999 d16y8) doesn't want to start while its hot (if i go for a drive and come back ... turn off the car and try to start it again... it won't start)... also my idle is messed up ... i tried putting on a gsr throttle body and couldn't get the idle down to 700.. which means its was damn near impossible to set my timing (argh!)... so i went back to stock for the time being... however.... now with the stock tb my idleis around 1200rpm (but sometimes around 7-800rpm... it fluctuates)... i don't know if the idle is related to the starting problem but my car is acting very strange... the idle doesn't jump around ... its just not consistent... and if i try to start the car when hot...i've managed to start it by mashing down on the gas and holding the key in start for a while until it catches... when it does it bogs and bogs until it finally catches... if i let go of the gas it dies... i have to hold on the gas for a while to keep the revs up until it gets going... this is driving my crazy!... my car was perfectly fine until i tried that tb swap... now my car won't even start (when its warmed up)!!!
help please!!!
thanks!
Have you checked simple things like air filter, fuel delivery, bad ground? It might just be a coincidence that it happened when you changed the throttle body.
maybe the t/b gasket since you changed it?? which did you use the y8 or gsr one when you put the y8 back on.
C
hmmm... air filter is ok... i have a fpr gauge and i think i have it set at 42 with the vacuum hose off... as for grounds... i will have to double check... is there a specific ground that, if disconnected, would cause this?... or would it be any ground?
thanks!
C
bseries.... i went back to the stock y8 tb gasket...
Also are you sure you hooked the wires back to the right places? I had two switched when I installed my new engine and had similar problems
C
pbmatty: are you talking about the connectors for the tps and map?
1 - 7 of 7 Posts
