1 - 9 of 9 Posts
91 Hatch rally car
Just what the title says.
We need to swap rear spindles from one trailing arm to another. What's the trick to get the torx head bolts out? They are wicked tight and lock-tighted in.
impact driver?
91 Hatch rally car
We already broke a torx bit banging away with a 1/2" impact driver. I'm leaning to grinding the heads off the bolts with a carbide bit since the bolts are really hard and don't want to drill easily.
CRX ECODiesel Ram
not sure i have only done it with a ratchet in the junkyard. used an 8 inch ratchet and a 18 inch pipe and they came right out.
91 Hatch rally car
Discussion Starter · #5 ·
Maybe a big cheater bar will be better than an air impact. Those torx bits seem to be a bit fragile.
I didn't mean air impact lol, I meant like an actual impact driver
I have yet to see ANYONE remove the bolts without lots of heat and broken bits.
91 Hatch rally car
Discussion Starter · #9 ·
Thanks for the help.
We f*@ked up the right side trailing arm playing with some suspension fabrication ideas.
These are getting hard to find in the pick-a-parts places. We have some of the drum brake versions, hence the swapping. We'll give it some more effort and then decide on the money/time equation.
1 - 9 of 9 Posts
