1 - 6 of 6 Posts
my transmission started to act funny did some looking up cant figure it out before I rip it apart. if the car is off the ground the wheels spin in park. reverse acts like neutral I can back up I feel it shift in between park and reverse. neutral I can drive in for a lil bit and regular drive works fine. what could be the problem. I have already adjusted the shift cable. so I know that's fine don't know where else to look, I have googled yahooed I asked jeeves and looked on here cant seem to find the solution cause they all say the shift cable is not adjusted.
\/Your Mom Was Here\/
Vibe GT
It does sound like the cable isn't adjusted properly.
i took it back off and the hole is perfectly aligned and done accordingly to the technicians version of the chiltons.
is it possible the shifter is bad because when I feel it in reverse it is at the top of the ridge before the reverse selector ridge again I checked the shift linkage and it is the way its supposed to be
yeah it was the shifter cable or the assembly went to junk yard bought new shifter assembly and now it works thanks for your responses
1 - 6 of 6 Posts
