1 - 4 of 4 Posts
Ok so yesterday I was driving my 98 civic lx
I came to a stop light when the light turned green I stepped
on the gas ,motor just reved up and
wouldnt go nowhere after like 5 secs it went
. I got home and checked the codes and
had p0700 and p0730 , also when I pulled up
to the drive way it rolled back as if it was stickshift
First off, this should be in the transmission section, but General tech is fine.
Some questions, first. Have you ever changed the fluid or had it changed?
Have you noticed any slipping while driving, especially while in certain gears, and at lower rpms?
Is there a whining noise coming from the transmission end of the engine while the car is in park or neutral, but it goes away when in gear and not moving?
I've not looked up your codes, but it's a good bet you've got a gear clutch pack going out, especially if you do have any slippage. The torque converter is also a possibility, but less likely. And if you can answer yes to my last question, just park your car and search around for a new transmission or tran/ engine swap, because it's about to die on you.
Check your ATF level and color. If its clean and to level, your clutches inside the transaxle are going out.
Hey newb, care to explain?
Lets discuss neutralized issues.
Is that a date?
1 - 4 of 4 Posts
