1 - 20 of 33 Posts
Sorry, if this has been covered 100x times. I can't find any thread relating to this.
I need to know how much transmission fluid to buy and what weight I should use.
I don't need something really nice like Royal Purple or Redline..
I'm going to buy the fluid at Kragen..
So any suggestions would be nice.. thanks guys!
Sorry, I don't have a manual..
I'm just shocked, all the cars i've ever owned needed gear oil.
Discussion Starter · #12 ·
To fill it, put a piece of 3/8 fuel hose on the end of the bottle and squeeze it into the fill hole.. this is simple and effective
Oh, sorry I should of been more specific. Where is the fill plug on the transmission? I don't know where it is.
Discussion Starter · #18 ·
Oh, I know.. I just needed to know where the fill plug was.
Sorry, if this is hella newbie. I just don't want to run into any issues.
I'm a better safe then sorry kind of guy when it comes to information.
· Brokedick Millionaire
92-00, remove the VSS, easy fill point.
Dump in 2 full quarts......I know only 1.8 is required, but then again I've never had a bearing failure either, go figure!
Thats def the easiest way to do it!
1 - 20 of 33 Posts
