1 - 7 of 7 Posts
1998 Civic
I am hearing a weird noise from my transmission like it is dry, is this something that happens when there isn't enough fluid in it or it time to change the clutch?
thank you,
1998 Civic
I didn't as I don't have a good place to jack up the car and look. If there is an easier way to do it I would like the suggestion.
68 Camaro
... thats a very possible cause of your problem i would recomend getting somehwere where you can check it... do you not have a jack (and jackstands of course:wacko:) and a flat patch of ground?
1998 Civic
I would have to go to a friends house to do it. Also is there an easier way to fill it besides the hole on the side of the transmission? I heard you can pull the VSS to fill it.
1 - 7 of 7 Posts
