1 - 20 of 21 Posts
R
Ok, I'm attempting to work out a good hwy trans with somewhat close-ratio and decent spacing... going into a 92 Turbo Hatch.
Here is what I came up with:
1st 3.250 (DX 92-95 Civic)
2nd 1.761 (DX 92-95 Civic)
3rd 1.180 (DX 84-87 CRX)
4th 0.937 (DX 88-91 Civic)
5th 0.750 (SI 93-95 Del-Sol)
FD 3.888 DX
Ok, is this possible? Can you put cable-trans gears in a hydro trans? Do the years matter?
Open for suggestions... this is mainly a commuter car on hwy w/ 75mph speed-limit, but mostly cruise @ 80+. So I'm looking for decent hwy pull and economy.
Rogue
R
transzex said:
can't mix those parts, just run a 92-95 EX tranny and be done, esp. with boost.
Cool, thanks! Trannies aren't something I'm well versed in... can cable and hyrdo trannies not be mixed? Or is it the years?
Rogue
R
transzex said:
your trying to mix 3-4 different generations of trannys, never gonna happen.
Ok, one last ? What about a 4th (0.937) from a 88-91 civic/crx? Will that work in a 92-95 box?
Rogue
sub-sponsor
93 civic
shit man run a cx tranny, we ran a d16z6 turbo with a cx tranny 1stgear about 43mph 2nd 84mph 3rd about 120 and then i dunno cuz theres no need to take it quicker than that
1988 Civic Hatch
while we're talkin about it, could i put a final drive out of a std tranny (4 speed, 88-91) into an si tranny(88-91), or into an hf tranny(88-91)
Y
I hav a civic 1.6 vtec sohc '98 auto....how can i get the revs to drop more in 4th gear....a new gearbox or can it me resynced....any ideas of other compatible auto boxes?
1988 Civic Hatch
transzex said:
HF and STD have the same FD............
nope, they have the same gear ratios, but have a slightly different final..well that is if the chart i was lookin at is correct. but it makes sense, why at 7900rpm im goin 80 vs on an hf when in at 7900rpm im goin a lil over 90
49 state HF and STD get 3.25 FD, Cali HF got weird 2.95 FD.......
Yet to run across a 2.95 FD.........but have found TWO 3.722 DX FD's, does your chart show them?
1988 Civic Hatch
um id ahve to find it again, but would this final drive i have fit in an si tranny?
D-Series Destruction Master
if you take an hf up to 7900, you have problems
96 hatch
Yet to run across a 2.95 FD.........?
i almost bought one of those like 4 years ago off my uncle. i got on the freeway and was like what the fuk this things doing 80 at 2300 rpms
1 - 20 of 21 Posts
