1 - 20 of 28 Posts
94 Civic LX
on my old tranny (s40 b000) my isb started going out so i swapped in a new s40 b000. i bought it off a guy for $100. anyways we finally got the swap done, and i went to go for a test drive. i put it in reverse and it move like 2 feet then just stopped moving. NO GEARS will catch at all. when i put it in reverse it has a grinding noise and then every other hear starts grinding but will never catch. i need this fixed by monday any suggestions?
94 Civic LX
EDIT: i just had a hunch and thought that maybe the axles were too short because i had to tug them to get them into the hub, sure enough i went out there and one of the axles had came out. so the question now, is what size axles do i need? i thought the s40 b000s had the same axles?!?!
check you shift linkage....it could be off or not tight enough
OR
one of you axles arent in properly and your tranny is sending all the power to the side not in right resulting in you not moving
OR
you have a bum tranny....did you put oil in it?
If its the same type tranny you had in there before there shouldnt be a difference.....try putting the axle in the tranny first then into the hub and just leave enough of the axle sticking through the hub to put the axle bolt on and then tighten so youre not pulling the axle out of the tranny again
you really gotta smash them into the tranny...like they slide in but then you gotta like grab the shaft and knock it in there hard and it will click in....there shouldnt be any gap between the cv joint and the tranny should be practically flush
94 Civic LX
lol... i have probably an inch gap...... i just put the car on jack stand.. started it and put it in first and let it idle in first. the driver side tire will not stop spinning and the passenger side tire you can stop with ease. i honestly dont even think the axle is inside the transmision.. ill post pictures...
yeah loosen the axle bolts and smash those fuckers in there till there isnt a gap on the tranny sides then your good....lol
and then of course tighten up the axle bolts again!
97 Civic LX
i just put axles in my car, you should have a bout 1/16 of an inch gap between the tranny and cv cup. also did you make sure the c-clip was still on the end of the cv shaft?? that's what holds it into the tranny. if mine was still appart i'd take a pic. i'm finding the passenger side difficult to click in so tomorrow i'll be looking for somewhere to put a punch so i can drive the axle the rest of the way in. after you get the cv in all the way you shouldn't have any other problems with it, but ya put the cv in the tranny first then the hub if you can't get it to click.
good luck, just make sure you get it all the way in first
94 Civic LX
alright i got it. i think somehow in the boot closest to the tranny i had the joint twisted up.. fits perfect now! nowthe only problem is my speedometer. its flipping the fck out. iv tried removing and unhooking and putting back in the VSS but its STILL flipping out. the speedometer is jumping around even at idle..
Good that you got that figured out, and for the speedo check all your grounds really good, thats what it sounds like to me
wrong,there should be 1cm gap and yes u gotta slam that fucker in.
94 Civic LX
alright gotcha.. i fixed my pass. side axle and slammed that bitch in but today the driver side axle came out cause i didnt slam it in. gotta go fix that now.. ill check the ground. the only ground i messed with was the tranny-to-body ground. its probably getting a shitty connection..
try a different vss...
okay theyr back in.. i sanded the end of my tranny-body ground and im still getting a jumpy speedo. i didnt touch any of the other grounds on the car so idk why its flipping out! its really really annoying...
mine doesnt even work till the tranny is warm, I think the VSS or whatever is going bad. There was another thread about it and its either the cluster or the VSS and since you are put in a new tranny its probably the VSS.
Did it click completely into place cause when I tried putting mine in after my swap I have two of the white sleeves in there and it wouldnt fully connect
94 Civic LX
Discussion Starter #19
the thing is though, when i bought the tranny off the guy, it came with a VSS with the connector cut off so i just took it out and put my VSS back in from my old tranny. it worked fine before but now its flipping the hell out. i think i might try a new one from autozone and see if it fixes it.
1 - 20 of 28 Posts
