L
This weekend I'm putting in my y8 tranny to match my mini me swap. I'm just curious. Will the speed reading change w/ the differnt tranny? Or is it all the same?
Thanks,
Jeremy
all the same, the VSS reads after all gear reduction inside the tranny. The only was to effect the speed signal, change your tire size.
L
Awesome information Mista Bone. I was hoping you would see this. :)
Btw, that y8 should be in in 5 days. I'm hoping the differance is as big as you say. :)
Thanks again!!!
92+ are interchangable.........matter of fact you can install a VSS where the speedo drive was on a 88-91 tranny......if you can get the cable drive setup out!!!!!!!
