1 - 12 of 12 Posts
T
ey guys just wanna ask if a d15b tranny already has a stock lsd? if none, what d traby has a stock lsd and a gud final drive tnx!
i save your ass when you wreck
94 hatchback cx
i have a d15b and i dont think i have lsd but when i burnout both tires spin.....
it will be clearly stamped " LSD" on the bell housing if it has one stock!
:hijacked: Notice the LSD Trans is all clean while the non-LSD is filthy as PHUCK!
Rexinre said:
Haha, thats cause I just took the Old tranny out and were about to put in the LSD one! W00t W00t!
:hijacked: Now if only they had messed up and given me a S20 ZC LSD trans instead of a S20 ZC trans[USDM Si] when I went to attarco to buy my DX trans :grin: :hijacked:
T
um, which is better s20 or s40? both have stock lsd in it ryt?
CR-Vtakin
your mom
Rexinre said:
Or if you look through the holes where the axles go and there is no bar you are good to go (LSD) if it has a bar, (no LSD)!
LSD
NON LSD
this is correct. there was even an option of a lsd automatic trans in japan.
Its only a stock LSD if it is stamped to be one... not all LDM's are LSD.
1 - 12 of 12 Posts
