1 - 14 of 14 Posts
97 civic hatch
grinding in reverse and sometimes wont go into reverse unless i disengage clutch then try it again, also car has a kind of ticking noise sounds like a bad valve but it goes away when engage my clutch? anyone know what it could be?
97 civic hatch
shit sucks the guy who had it before me said he put an integra clutch iin it? how? b and d series gotta have different trannys
86 MR2
See above...
Common Honda STD trans issue. The rear gear has no synchro, so it will grind sometimes. If it won't go into reverse immediately, put it into 1st/2nd and move forward slightly...then put it into reverse.
97 civic hatch
i really have no idea what this noise is? like i said it sounds like a bad valve but it goes away after i engage the clutch anyone know of this?
define "engage the clutch".......as I think you are disengaging it.
94 Civic LX
throw out bearing or input shaft bearing
what he said. just replaced mine to a bad input shaft bearing. if its a throw out bearing it will make the noise with the clutch pressed in. if its a input shaft bearing it will make the noise when the clutch is NOT pressed
97 civic hatch
makes it when the cluth is pressed and comes back a couple seconds after i let off hte cluth but my tranny seal is leaking too...:(
97 civic hatch
yeah its a weird ticky noise almost like a rod or bad lifter or something but only happens when the clutch isnt pressed in but i can hear it all thru all of the gears idk what the hell it is i might bring it somewhere for them to look at it so i know exactly what it is
1 - 14 of 14 Posts
