1 - 4 of 4 Posts
Boost Gets You Laid
Del Sol
So I'm looking in to going to Bristol Street Fights in May. This is the first time I'll be at a track with a car that's mine haha.
Given the name Street Fight, no slicks permitted for this event.
Current setup:
Stock rebuilt y7
TD05H set for 8 psi(Will probaly shim my WG for 10psi)
Matrix sleeve-overs on new Hon-Duh struts
4K RPM Launch set(uberdata, think this is too high for street tires)
I have 2 sets of tires I can go through:
Douglas Performance GTH (softer rubber compound)
Cooper Cobas(Harder rubber compound than the douglas tire)
All tires 185/60HR14 on Del Sol 5 spokes. I also have access to a set of Douglas Performance GTH 195/60/14 I can toss on my spare set of steelies
Also, drop tire pressure to say 15psi? How will a street tire heat up vs a slick(longer or shorter burnout in the box?)
oooo and one other thing comes to mind concering tuning. All adjustments reguarding tuning have been made at 3200ft above sea level. Would a 1500ft differance Majorly effect the current tune?
Ninja edit: Car uses 93 Octane on a daily basis, anything effected with a 50/50 mix of 93 and 104?
Lurking... ಠ_ಠ In Your Thread
ES1 Civic
the douglas tires may just heat up as fast as slicks.
ES1 Civic
hell, do that shit too!
1 - 4 of 4 Posts
