1 - 10 of 10 Posts
I got my car dyno tuned about few months ago, since then everything was fine...the other day my tps sensor went bad after changing the intake manifold and i couldn't get the original setting on the tps. I have put the tps back to its original setting at .5V at fully closed throttle. I don't believe it was exactly .5V when i went for tuning. Now when i start my car, i get a lot of misfire when i hit Wide open throttle. Any one can post any remedy or would i have to go back to get it retuned on the dyno...any thoughts...?
Thanks,
Nik
Administrator
Honda
Talk to your tuner, normally they would be happy to help you set it back. In fact they should have checked it before tuning.
but my assumption is correct? Moving the TPS around will change the fuel and ignition maps correct?
i don't remember what originally the tps was set to when it was dyno tuned. So now i don't know what voltage to set the tps to. I currently have it set to the stock oem setting of .5V at full closed throttle. What difference i have noticed since i changed the tps is that it takes longer for me to start the car, more cranking revolutions. Once it starts, it idles fine but then trying to launch off the light at full throttle, i get multiple mis-fire going on...so i am assuming its due to the tps setting being different...or would the computer adjust the minor different in the tps and the problem could be else where?
It probably is lean miss fire or to rich / flooding out. Changing the tp setting changes what tip in needs to be. You may just play with it and see if you can get it back to what it was with trial and error.
Hold up. you changed the intake manifold????? and the tps broke or you took it off ( forgetting to mark it) and then you put the same one back on. at .5 at idle. clarify .
91 CRX HF
take it back to the tunner and get him to reset it at no cost..
I don't know if the tuner has any obligation to do anything, since he changed the manifold himself. It's not the tuners fault he changed things. On the other hand, it doesn't hurt to ask your tuner for a little help.
I thought the fuel and timing maps come directly from vac and boost readings, and TPS is just for decel, idle, and tip in. Correct me if I'm wrong. I would think his problem is elsewhere though. What exactly did you do when swapping the manifold. Did you remove the dizzy at all? What was the car doing to make you think the TPS went bad in the first place?
Thats what i am unsure about. I was under the impression that the tps has a role in the timing and fuel maps? The car ran perfectly fine until recently it started mis-firing when i rev hard or try to launch fast. So i changed the tps sensor thinking that might be the problem but i never gave any consideration to noting down the voltage because i figured it was stock. Now it occured to me that maybe the tps setting was different when it was dynoed. Other then that, i didn't touch any other thing like the dizzy or anything. Maybe i should check the dizzy...could be the rotor inside the dizzy...
Thanks all that replied
1 - 10 of 10 Posts
