1 - 3 of 3 Posts
does the mofo come off???dosnt look like it, but figured id see if u guys had any ways to replace them without replacin the whole TB...its on DPFI now, but i have one on a b7 mpfi that looks the same, will it work??and how does it come off??!!!
D-series wise guy
I believe all 88-00 tps's are the same. The tps is riveted on. You have to cut a slot in the rivet and use a flathead screwdriver to get it off.
Don't forget that if you remove the tps, that you have to recalibrate it...
http://www.superhonda.com/forum/showthread.php?t=239633
1 - 3 of 3 Posts
