1 - 9 of 9 Posts
formerly Kit88
ek hatch
I just make a obd2a to obd1 conversion on my 96 hatch, I'm using a chipped p06 ecu, and change the im from y7 to y8.
I'm using ectune and datalogging, but map and tps values always stay with no changes, no matter if I push the gas partial or complete, to reading variations on both sensors.
Also the readings on the map on idle, are always at .5 bar, not at vaccum, this is wierd, cause I don't have vacuum leaks at all.
I'm lost
Pleas help me guys, need this car running asap, and is smoking black a lot.
I already try changing tps sensors and another map sensors but, same problem.
WTF ???????????????
hmm so you changed the TPS and MAP and still doing the same thing?
If you made your own conversion harness try and source the problem there loose wire or something either then that it could be software related, ask calvin!
also did you mix up the connectors?
formerly Kit88
ek hatch
not mixed connectors, and also not loose wires on the convertion harness.
formerly Kit88
ek hatch
Problem fixed, tps was broken.
formerly Kit88
ek hatch
it was wierd, tps was broken inside, the part that holds the spring was broken, so the sensor was reading the gas pedal action.
Poop Sock
wrx & slut rex
i had a tps mess up on me one time. the little tab on the inside rotated 180* I even adjusted the spring and took it out, rotated it, ......nothing fixed it. i bought a new one for 50. problem solved. gl
1 - 9 of 9 Posts
