1 - 18 of 18 Posts
Honda
Hey mates,
found over here with nice price pistons for Suzuki VITARA/SIDEKICK/BALENO 1.6 16V.
Seller says they are for engines G16, B and D.
Brand Toto, code 1718033 + 33-2728.
My block is sited at machining shop.
The package with p2p0 combo is in customs, but they are 75mm. And only now guy from machining shop just tell 75.5 will be better.
I'd prefer not waiting a month and a half to reassemble with 75.5 from EUA.
Anyone used this brand?
They are the right ones for turbo D? I mean, they are equal to YCPs in design, pin positioning, etc.
Well, thanks for any help.
Cheers!
My car...or my truck
If the machine shop says use 75.5....you know, at face value, probably should do what they say. Pretty sure they are boring your block out .5 and you will need a bigger piston to properly fill the hole
Reactions: slo_eg8
Sloppy Jalopy
Try them out and tell us how it goes.
Company Profile
Company Name TOTO INTERNATIONAL CO.
Address 479-1, MOOKBANG-RI, SANGDONG-MYEON, GIMHAE-CITY, GYUNGNAM, S. KOREA (ZIP: 621-811)
TEL/ FAX TEL: +82-55-345-4401 / FAX: +82-55-342-8801
G. Manager MR. SUNG-CHUL KIM (ALSO KNOWN AS MR. BRIAN KIM)
SALES OFFICE IN TOKYO TOTO ENG. PARTS CO.LTD.
5-80, AOBACHO 2-CHOME, HIGASHIMURAYAMA-SHI TOKYO 189-0001 JAPAN
TEL: 81-42-395-2300 FAX: 395-8593
Email [email protected]
[email protected]
Main Items TOTO PISTONS FOR JAPANESE & KOREAN VEHICLES
TOTO PISTON RINGS FOR JAPANESE & KOREAN VEHICLES
TOTO LINERS FOR JAPANESE & KOREAN DIESEL ENGINES
TOTO GASKETS FOR JAPANAESE & KOREAN VEHICLES
Handling Items FUEL PUMPS (MECHANICAL & ELECTRICAL)
SUSPENSION PARTS, ENG. VALVES, ENG. BEARINGS
OEM PARTS FROM TIER-1 FACTORIES FOR HYUNDAI MOTOR CO.
FEATURES OF TOTO PISTONS
LOW PER-MILE COST MAKES TOTO PISTONS THE MOST ECONOMICAL PISTONS AVALIABLE.
THEY ARE DESIGNED, ENGINEERED AND MAUFACTURED TO GIVE HUNDREDS OF THOUSNADS OF MILES OF SATISFACTORY PERFORMANCE.
THEY ARE MADE FROM THE FINEST ALUMINUM ALLOY AVAILABLE.
THIS ALLOY HAS A SILICON BAES, GIVING LOWER COEFFICIENCY OF EXPANSIOIN THAN OTHER ALLOYS USED IN PISTONS
TOTO PISTONS ALSO FEATURE A SURFACE TREATMENT WHICH ASSURES A SMOOTHER RUNNING ENGINE, BETTER LUBRAICATED CYLINDER WALLS AND FREEDOM FROM COLD-START SCUFFING.
TOTO PISTONS ARE DESIGNED WITH A RUGGED INTERNAL CONSTRUCTION - A STUDY PISTON WHICE WILL GIVE EXCEPTIONAL SERVICE.
1971
* OCT. Established in 1971 AS A JOINT VENTURE WITH TOTO SANGYOSHA CO.LTD. TOKYO, JAPAN.
1989
* MARCH. STARTED TO SUPPLY OEM PISTONS FOR HYUNDAI MOTOR CO.
2003
* MAR. PISTON SECTIONS BECAME INDEPENDENT , UNDER FULL RESPONSIBILITY OF TOTO INTERNATIONAL CO.
2009
* AUG. MOVED TO CURRENT PLACE
Love the Civic
^ like no one has ran 75mm vitaras before huh?
If you are boring out the cylinders then you want to go a bit bigger, waiting equals proper function then wait. You will get piston slap which leads to a boboo down the road. Might as well get down the road under power and not walk it off right?
that makes too much sense. logic doesn't work around here:booty:
toto tend to crack ringland on other motor. the material is no good. no experience on their vitara.
yeah, an extremely hypereutectic piston (like they're bragging about with regards to the low coefficient of expansion) will be strong but brittle and susceptible to cracking
Reactions: slo_eg8
Love the Civic
His postal service is on strike...I think.
Honda
I meant Mail service over here, sorry, lol.
I think i'll make a try with totos. Block came from machine shop.
1 - 18 of 18 Posts
