1 - 7 of 7 Posts
Is it posible to get 200 + Ft/lbs torque out of my d16z6 running less then 5 lbs of boost or no boost at all.. bc my friend is gonna drop an Ls in his 91 hatch and i watn to be able to spank his ass bc he is the shit and well he isnt ... wat can i do to get that much toprque with very small boost or no boost at all if possible ..
R2.....Zap Balls
94 Ex coupe
only with lots of n20 if you don't go turbo. If you do go turbo, you'll def need more than 5 psi.
you'll need about 10-12psi to achieve that depending on many things like build, turbo size, etc. 5 psi isn't going to do.
I almost cracked 200 ft-lb at the wheels at 15 psi from a greddy kit... would have made 250ish hp if the boost held to redline.
But yea, look at dyno charts from N2O D16Z6's... Since nitrous if introduced into the intake at a constant rate, you get more nitrous per combustion event at lower RPMs, thus a massive torque spike when the nitrous comes on - it falls off relatively quickly as the RPMs rise but you get a ton of instant power down low. A 50 shot dry kit might get you close to 200 ft-lb at the crank.
A 50-75 dry shot should get you in position to romp on an LS.
Don't forget to retard the timing and tighten plug gap.
1 - 7 of 7 Posts
