1 - 4 of 4 Posts
I recently did some pulls on virtual dyno, not really looking for numbers, just the graphs.
Anybody have any ideas on why I have such a steep fall in torque (and power) after about 5k? I thought the turbo was running out of breath so I turned the boost down but still have the same graph.
Setup:
D17A2 stock block, stock head
50 trim .42/.48 turbo
Log manifold
2.5" downpipe to 2.25" eBay exhaust
500cc injectors
Hondata Kpro running a street tuned basemap. 14* timing at 12 psi
12 psi:
https://drive.google.com/file/d/0B-FHfTSQWmlTVE5DN1ViS0pTb2M/view?usp=sharing
11 psi:
https://drive.google.com/file/d/0B-FHfTSQWmlTcDd3WUlfSG5YNnM/view?usp=sharing
same
Setup:
Log manifold
500cc injectors
12 psi:
11 psi:
I'm gonna say the stock cam might be your issue. Also the log manifold possibly. for high revs, a ram horn would be better but you will see an increase in lag if you do that.
stock cam for sure... also a lot of power for stock rods, they don't live super long at 225ftlbs
Discussion Starter · #4 ·
Awesome guys, thank you. I thought maybe it was the cam (and IM) but didn't want to cross off the exhaust as being too restrictive or turbo being too small.
A built motor should be going in the car soon, if not a K20. I got ARP head studs and rod bolts on the current one to help out a bit.
1 - 4 of 4 Posts
