That is the question.
My new y7 block is @ stock specs 75mm bore (zero miles on a virgin block/crank, factory cross hatch is visible) my Arias pistons are 75.05mm so bore/hone work is needed. The extra .05mm = .0019 inch...a pretty small amount as far as over boring goes.
Ive never personally done bore work. I want to know if its necessary for the machine shop to "bore" it when its such a small amount? Or can that amount be removed from a simple hone?
I have a good bit of $ sunk into this build and want the rings to seal well.
Thanks guys
Arias 11.5:1 forged pistons
part# 3330900
75.05mm bore
-0.4cc dome
30mm compression height
This thread is boring...
Ok, in all seriousness; get a machine shop to fit the pistons for you. It'll cost around $100 from the quotes I've gotten, and you'll have the peace of mind that they fit just right.
agreed, this is getting boring haha
and the machine shop is what ive decided on...
just wasnt sure if fine adjustments were easy to make using a hone
