If my Dizzy is all the way retarded in order for my car to run at least somewhat decently, should I advance or retard the cam gear? Thanks!
racist-bigot-sexist-homophob
i say u get a timing light and do it right the first time b4 u fuck somethin up.... oh and its called the search button!
I agree. Start over.
I'm working on a d16y7 block with a d16z6 head. I have set it to TDC many times, and it always seems to be at the right timing. Still, however, I have to have the dizzy all the way retarded for the car to run decently. Even then, it sometimes boggs on the highway which then causes me to turn the car off and on quick to get it going again. The same problem occured when I had a y8 head on it. I'm starting to think it might even be an ECU problem
I set both the crank and cam gear to TDC. Idk if there is supposed to be an offset with the different head
