yea, ive used a bolt extractor bit and drill and was able to pull out a busted bolt while the motor was in. keep the tap slow, straight, and steady when your doin it
I have never tapped nething before, so it this possible with the block in the bay?
probably not. there might be enough room for one, but its going to be a pita to get the tap in there straight. you could always try and drop the engine down a little till you can get a straight shot at the bolt hole through the wheel well.
