Shoot me!
2000 hatchback
I just did a y7/y8 head swap and when i start my car i notice the timing belt looks real floppy like a banjo string front and rear is there a way to put tension back on the belt via tensioner pulley access hole without taking off the crank pulley i also only have the top belt cover off bottom one still on.
Just line the crank back up to tdc. Check your tensioner to make sure it's loose*. Make sure the cam/head is lined up correctly. Put timing belt on and rotate the crank counterclockwise a few teeth which will take the slack out of the belt. Tighten the tensioner and rotate the crank completely back around and check your marks on the crank and cam/head. You might want to do it a couple of times if your an obsessive-compulsive personality.
*Tensioner may be bad. If it does not keep tension this time then change it.
I know for the d16a6 and some older models you set it as dog says by setting at tdc then rotate 3 teeth then tighten down the tensioner. But newer models may be different.
95 CX Hatch
Yep and even after you tension it properly it will LOOK floppy when running and always have a tiny bit of looseness to it. Most people just never notice because well, they never had a reason to look.
Shoot me!
2000 hatchback
Yeah when its running it looks floppy but when its off its fine i've been having a misfire and idle problem but i think its possibly the injector of that cylinder or the injector circuit. I thought the floppyness of the belt could be atributing to that but i think i could eliminate the belt now thanks for your input guys.
