Hey, sorry i did try search but did not found hat iam looking for.
Ive done the timing belt with a friend who is mechanic and we were confused. The mark on the crankshaft pulley were in line with the plastic cover, and 1st one is in OT as we checked with a long screwdriver.
But the camshaft pulley makes us mad, if we use the 7 oclock mark its fine, but the two horizontal marks are not even with the cylinder top. My friend says if he looks on the cam it should fit this was. On the pic you can see the problem, maybe you could give me a hint.
Sorry for bad english and thx for reading
88-95 D16, 7 o'clock pointer
88-95 D15, two horizontal marks
92-95 D15 VTEC-E....lets not go there :)
'93 / '95 Del Sol Si - '95 DX Coupe - '98 Civic Hatch - '00 Accord EX F23 Manual
Yeah, that's the way it should look. Those horizontal marks are for B7s or B2s. They all use the same cam gear.
Also, don't be freaked out if the 7 o'clock mark isn't exactly lined up with the pointer. If it's a tooth off in either direction, it will be painfully obvious. But if it's close, it should be good. Mine looks like it's at about 6:53 PM. (y)
