The tie rods on my EG need replacing. What is a good brand of Tie rods to go with? OEM? Aftermarket?
I have a lot of play in my steering before the wheel of the car actually starts turning.
MOOG (sp?) are good parts but any tie rod will cost you about 30-50 bucks1
I dont like the guess which brand; autozone sells well atleast the ones around here!
2001 Z3 Coupe 3.0i
'Camelot' makes good ones too. They have Zirk fittings for refilling the grease. Cost around $30.
here is another question...do I need to replace the inner and outer rods?
Should I just do both while i'm at it.
2001 Z3 Coupe 3.0i
The outers wear out more quickly, and they most likely need replacing. The inners you should test for play. They should not rattle around at all inside their ball joints.
Discussion Starter · #8 ·
thanks, I'll replace the outer tie rods first and then if the problem persists i'll replace the inner.
