1 - 20 of 46 Posts
just finsihed my install and my BOV doesnt work :(
are they adjustable or do i need a lower psi spring or something?
cheers.
luke.
i dont know why i asked about the boost controller, i was thinking about the wastegate...
check and see if there is a spring on the inside, and if the adjustment nut/stud needs to be backed off...
are you revving it in neutral to see if it blows off, or under a load driving...?
ok i have a line off the compressor housing which is split with a brass 6mm tee. one line goes to the EBC and then to the top of the waste gare, the other from the tee to the side of the wastegate.
my BOV come off one of the large port on my skunk2 IM where my PVC used to connected.
and yes i am on a basemap.
Discussion Starter #16
the instructions just showed how to install it, never anything on seting it up.
its to 10psi but ive only run around 7ish on it
Hi hater!
I know for mine I have to have to build over 5psi for it to blow off Im thinking your fine maybe talk to go autoworks I know he sells tial he might have some insight into it or hit up tial themselves. But Im guessing this has more to do with you being on base map just take it easy on the car and let of the gas easy to prevent surge
1 - 20 of 46 Posts
