1 - 9 of 9 Posts
well im boosted again and better this time.. almost got all my bugs worked out but i have the older style 50mm tial bov, i bought it with the 7 psi spring because i read before purchasing hondas like the lightest spring, it was all the way open at idel then would close with very little gas, i shimmed it as much as i can keeping the spring in the hole to keep it centered, and got it down to barley having a gap, ive hear you barely want to see the o ring and mines all the way exposed plus alittle.. with my -19 vac tial calls for the 11psi spring, but id hate to go to big and not be able to go down, so should i get the 9psi and if its not enough shim it, or will i not be able to shim it enough..thanks ahead
I had the lightest spring on my turbo setup, it would be cracked at idle, just enough to barely see into the pipeing, never had a problem with it!!
Oh and i started wih wha tial recom. But it never blew off, then went one lighter got some blow off, then to the lightest(w/small shim) and it was titts.
thats about where i am not where i can barely see into the piping, guess ill run it for a while and see how it dose..i might just get the next stiffer spring so i can take some of the shims out and have more room to work with.. thanks for the input
problem solved ordered the 2nd softest spring believe it was white and put 2 washers in to get barely cracked at idel
Any idea with size spring it was? Ill be ordering a 50mm wastegate probably next wk and it comes with a 8psi spring. And would rather have all my problems solved before last min.
1 - 9 of 9 Posts
