1 - 1 of 1 Posts
I saw this while I was searching about cleaning a TB!
http://spdweb.net/index.php?option=com_content&task=view&id=18&Itemid=41
I just want to know have any of you done such thing with TB before?
If yes, was it useful?
Could you describe how you did it?
Did you put gasket seal on both sides or only on one side?
Do you have any idea about setting the throttle stop screw? How close or open the valve should be when it is in close position?
I want to clean up my throttle body so I need to know before I do anything wrong! Last time also a mechanic touched the throttle stop screw so I want to know if current position is ok. Now when I look inside TB, I can see the light from other side!
Thanks
1 - 1 of 1 Posts
