1 - 14 of 14 Posts
Here is a nice inexpensive TB for those high-HP builds.
We also have larger sizes (74mm opening/70mm plate), but for the money these 68mm ones are tough to beat. You can even add on a new tps for only $29 when you buy the TB. Add a TB mounted map sensor too (DIY3bar, DIY4bar, Hondata 4bar, etc) for the ultimate package discount.
Check out these pages for more details:
68mm ($169):
http://www.xenocron.com/catalog/throttle-body-68mm-p-372.html
74mm ($249):
http://www.xenocron.com/catalog/throttle-body-74mm-p-374.htmlhttp://www.xenocron.com/catalog/images/68mm-throttle-body.jpg
D-Series Destruction Master
Will these fit directly to Dohc ZC intake manifold? or need adapter for it?
OBD-0 or OBD-1
I'll look into it, but if a normal D/B tb will fit your IM then so will this.
-Jay
If it's an OBD-0 DOHC ZC, then it needs to be 88-91 D16A6 compatible. Not sure about OBD-1 DOHC ZC throttle bodies tho...
Someone should make a small big tapered tb for N/A D's .A Stock size (55mm) Tb and a taper from 65mm (or more)is possible with a new thicker tb. ;)
'96 Civic EX
Nice tb's wish you had 62mm.
Ditto. :(
I just had an Edelbrock manifold shipped to me which allegedly has a 62mm opening, would really like a matched throttle body but will use D16Z6 one until then.
(Also, first post in over a year of registration.)
1 - 14 of 14 Posts
